Hello Al
many thanks for this.
Yes I have heard of the same problem of the electronic ignition kits affecting the tachometers in early MGB instruments (RVI type) but not the later versions (RVC type, the designation is printed very small on the face of the dial) for the same car because of the issues you mention. However, having tried those kits in friend's early MGs, they do work (whether only for a time is yet to be established) notwithstanding the warning.
Anyway, I will run the car without the tacho when I next attack it just to see if there is a correlation in this case: as I said, the immobiliser worked at the tacho to ground the coil.
re your other post; I have not had any chance to get to the car this past week due to weather and parts availability. When the fuel sender float arrives i can work through logically. However certain points I can answer now.
1 the cutting out issue only occurs on the road (apart from once on the driveway)
2 carb cooling fan operation - it operates if I jump it or use my over-ride switch; I have not got the car up to temperature since we last spoke
3 ignition timing: yes it is slight advanced to accommodate modern fuel and the dwell is spot on per the book. Used timing light and good meter.
4 temp of coolant - it climbs steadily to 90deg and then is happy there and the rad fan starts and stops nicely; no variation in temp before cut out. Using the temp gauge on the instrument cluster
5 I suspect that the car had the fault since I bought it; originally it was masked by general temperature problems, eg boiling over, massive increase in temp, blowing the coolant hose off the (damaged) choke unit spigots (now replaced). I did a flush and replaced the thermostat to a lower opening temp and as the rad seemed patchy replaced that too.
6 ignoring the above, the fault "seemed" to start after I fitted an inline filter before the pump (the filter's flow orientation is correct way round!) and the same happened with my 500 too....that cuts out after a similar time. They are good filters and cause no problems else where so I do not suspect them but it may just be a coincidence because they do not seem to act like a shut off valve.
Nevertheless, I am going to delete the filter for a while, though it makes it hard to see fuel flowing.
PS I have tried to reply to the PM, though the contents are the same here, however, the page will not let me.
Best wishes
RDS
