I spotted from earlier posts that currently have non ballast coil fitted(-:Hello Jack
re: Dead but not short circuited condenser usually means very hard to start engine or no start at all due to weak spark.
Engine starts well with 2-4 pumps of the accelerator pedal (prior o start) to re-set the choke.
Re Ballasted coil: no, this is a nominal 3 Ohm coil (actually 2.7 Ohm primary but I have added additional heavy duty resistor to bring up to 3 Ohm, no difference though anyway). NB I do not think the UK model uses ballast coil ignition.
re pump: I tested valve leak and it is ok, pumping rate however was not testable. easy to test with an electric pump, less so with the mechanical pump fitted, annoyingly.
RDS
Was wondering if the is a ballast hiding somewhere in car.
With ignition on and points closed what is voltage at coil +ve ?
Strongly suggest using original coil if you still have it.
don't know what is going on with your current coil secondary windings at 20,000 ohms. 2.7ohm primary should not require a 0.3ohm resistor in +ve feed just adds another component that could fail.
Gunson lo gauge can be used to check fuel pump pressure and they are quite cheap to buy.
Are the pipes on carb attached correct way round if carb has a return pipe to fuel tank?
