I worked as a Fiat Mechanic back in the day. We were frequently pestered by owners asking about their oil pressure gauge readings and worrying unnecessarily.
As others have said, these gauges are not particularly accurate - think of them as a styling feature, to make the car look 'sporty'
As long as the oil pressure warning light doesn't come on at tickover or at any other time, your oil pressure is probably fine. If you're still worried or want to verify your gauge readings, you can always connect up a proper test gauge (an accurate one
) at the oil pressure switch or gauge sender unit tapping point on the engine.
Most Fiat oil pumps of that era, were gear type pumps driven from the camshaft or auxiliary driveshaft i.e. at 1/2 crankshaft speed, so will never be likely to generate impressive oil pressure at idle or low speed and at higher engine speed, the pressure relief valve may open to control pressure.
Afaik, a petrol engine needs 10 p.s.i. of pressure per 1000 rpm, so about 7psi at idle (just about the trigger point of the oil pressure warning light sensor), 30 psi at 3000rpm (cruising?) and 60psi at 6000rpm. It wasn't unusual on some Fiats for the oil pressure warning light to flicker on and off at idle after a fast drive (oil hot). Was never a problem, providing the light went out as soon as the engine speed was raised.
There's little point in trying to generate higher oil pressures, puts more stress on oil pump drive components, absorbs more power, can aerate the oil - frothy oil doesn't lube bearings very well. Some Fiats used to shear the serrations in the oil pump drive gear.....others could burst oil filter canisters if the pressure relief valve stuck...
Conversion factor:- 1 Bar = 14.5 psi
AL.
