| Thread Tools |
![]() | #16 | ||
Posts: 61 Thanks: 0 Trader Rating: 0 ![]() | Re: Radiator advice, please! yes same ones. scirocco good find but like i said the extra faff put me off!! Others will be nore adventurous... cheers RDS
![]() | #17 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | Re: Radiator advice, please! Hi I replaced my X/9 radiator with an alloy one from Alfa 33, slightly smaller in surface area but is deeper, Dropped engine temp by 15 degrees, and never over heats thru mountain roads. Can be found cheap on eBay. Had to modifiy bottom mount and add top bleed hose,
![]() | #18 | ||
Posts: 61 Thanks: 0 Trader Rating: 0 ![]() | Re: Radiator advice, please! hello Tony any photos of the modifications?
![]() | #19 | ||
Posts: 11 Thanks: 0 Trader Rating: 0 ![]() | Re: Radiator advice, please! Hello, I have fitted dual fans at one point.. It is true the second fan needs a secondary relay triggered off the temp switch and a second power wire installed from the battery. It works ok but what I found was these stock motors on the fan draw a termendous amount of current which draws and loads the alternator quite a bit then resulting loss of power. What I ultimately done was aquired a Marelli motor out of a Lancia fan which I had installed on the stk X19 fan support brackets.. The Marelli fan (used also in vintage Ferrari and Lambo's) is very efficient and quiet. Another thing to check as well is the water pump flow. Pumps are known to get weak in pressure overtime and will flow well with higher RPM but flow not so well when idling.. there is over 11 liters of coolant to push around in the X19. I hope this may shed some insite on your dual fan question.
![]() | #20 | ||
Posts: 61 Thanks: 0 Trader Rating: 0 ![]() | Re: Radiator advice, please! Hello Breeze2 many thanks for the input there. I have installed the second fan and motor (am glad i did that before installing the new radiator) but have not connected anything to it yet. Yes, I was worried about the feed wires also. I was thinking to uprate the relay and the wires from there to the junction where the two fan feeds separate. The draw on the alternator is worrying: measured when running at 12-15A each with an initial much higher cut in spike (measured at 75A!). I say this is worrying because when the single fan cut in the other day i immediately had rough running. This happened twice in succession. However those more experienced than me say that it was merely a coincidence. cheers RDS
![]() | #21 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | Re: Radiator advice, please! Highly recommend the texas heat radiator from vicks, I have one and it fixed all my overheating issues! Decent price too
![]() | #22 | ||
Posts: 61 Thanks: 0 Trader Rating: 0 ![]() | Re: Radiator advice, please! good info thanks. I am awaiting electronic ignition to be set up correctly before i can test my ally rad better.....
![]() | #23 |
Posts: 8 Thanks: 0 Trader Rating: 0 ![]() | Re: Radiator advice, please! Watch my latest episode on the fiat x1/9 to see how I solved my cooling issues, including installing the texas heat radiator from vicks
__________________ You can follow my x1/9 build series, as well as many other classic car videos with the following links www.youtube.com/revtek https://www.facebook.com/revtek https://www.instagram.com/rev.tek |
![]() | #24 | ||
Posts: 61 Thanks: 0 Trader Rating: 0 ![]() | Re: Radiator advice, please! Hello pal I really enjoyed your video! very well presented and produced! Can you post details of the fan please? Does it have a greater current draw than the original? I was going to fit two original types, ie add another to my new rad set up, but think youir set up is better Also, I see you were using what looked like a factory manual which I'd like to track down also. Could you give me any details please? If you have done other videos, i will look forward watching them too. Keep up the good work, that video was inspiring. cheers RDS
Thread Tools | |
![]() | andy1 | Panda | 6 | 05-01-2015 20:28 |
![]() | AllenLowe | Punto (Mk1) | 0 | 05-10-2010 19:56 |
![]() | peter330 | Grande Punto | 2 | 16-08-2010 12:51 |
![]() | littleonyxguppy | Bravo / Brava | 9 | 22-10-2008 18:03 |
