Old 26-03-2016   #1
Ireland
Correct Wheel Nut torque
Does anyone know what is the correct wheel nut torque in NM for Cromodora CD 58 alloys? (3 spoke design)
Irish Cento is offline Reply With Quote Quote
Old 27-03-2016   #2
Ireland
Re: Correct Wheel Nut torque
Found the answer 98 Newton Meters (72 foot pounds) for X 1/9 alloys
Old 27-03-2016   #3
Useful. I must admit I have never used a torque wrench to fit wheel bolts.
I have stripped a couple of cheap aftermarket wheel bolts with a long bar. I guess that's the main risk.
I noticed that the CD 179 tron wheels have no steel shoulder around the bolt holes like some alloy wheels.
purf is offline Reply With Quote Quote
Old 03-09-2019   #4
Canada
Actually you will deform the threads, both the lug and the threads in the hub. You really should not need a long bar to tighten the bolts, generally with a proper torque wrench you will question if they really are tight enough.
With a regular 1/2" socket you will have to put quite a bit of strength into it. Threads are a locking mechanism, if they are in good shape they should not come loose. I have always used anti seize on my lugs, it allows the threads to slide better and achieve the proper torque. If your threads are dry, they can bind and not actually get tight enough. If your threads are stretched then you may have issues.
If your lugs are seized, or someone over tightened them, then you may need a bar to remove them.
There is a fine line between "hobby" and "obsession"
my wife knows about the "hobby"
ricar is offline Reply With Quote Quote
Old 25-09-2019   #5
Thanks Ricar
The question is - how long is a 'long bar'...
I was using a supermarket wheel brace, and they really were cheap aftermarket wheel bolts... horrible.
I have learnt my lesson regarding over tightening bolts on Italian cars. Easily done with a 1/2" ratchet. Some good advice I recieved was to use a 1/4" set instead!
I had a Renault wheel brace snap on me when I had a puncture once! A lot of mechanics over torque the wheel bolts or lugs.
Old 25-09-2019   #6
jimboy has donated!
Car companies supply short small wheel wrenches for a reason.
jimboy is offline Reply With Quote Quote
(T) wheel nut torque nealus Punto (Mk2/2b) 5 14-12-2008 19:55
(G) Wheel Nut Torque KurtB Stilo 5 01-06-2008 20:52
(G) Wheel Nut Torque Tillerman Ducato 0 27-11-2007 17:49
(G) Wheel Nut Torque Settings djowen999 Punto (Mk2/2b) 2 01-09-2006 18:45
(T) Wheel Nut Torque Settings djowen999 Punto (Mk2/2b) 1 01-09-2006 17:02
