vale of uscon
Member
- Nov 20, 2009
- 40
- 70
Does anyone have any tips on changing the clutch master cylinder?
My mate & I have tried all methods, for bleeding the clutch and we just can't get the air out. Elevating the back end, slow pressure on the clutch pedal, depress pedal close off nipple release and anything else we can think of.
I assuming we have a small leak somewhere, which is letting air in. It could be the supply pipe from the bottle to the master cylinder, it could be the cylinder itself. either way change them both and rule them out!
So I'm preparing myself to change both the supply tube and the master cylinder.
Before I start, I just thought I would post the question.
The Haynes manual makes it sound simple, but then again doesn't it always.
Thanks,
Simon
Thanks,
Simon
