Aux shaft bearings are available as finished or semi finished bearings. If the bearings you have are semi finished, they need to be installed into the block, and then precision reamed or honed to size. This is difficult and expensive to have done as the hole to be reramed is "blind" (i.e. it doesn't go all the way thru making it a more difficult process)
If they are finished bearings, then they can be installed and the inside diameter will be correct as is. (hopefully this is what you have, if they are not I have finished bearings for sale.)
Installation isn't so much difficult, but requires a couple of dedicated tools to push the new bearing in without damage. Simple to make if you have a lathe, I made mine from brass stock. You have to be careful to align the oil delivery hole in the front bearing, and the inner bearing must be fitted so the groove in the bearing is aligned with the hole in the aux shaft. Not difficult at all, but fiddly.
Nice thought about transferring all the innards to a new block, but it won't work, sorry....
1300 is 86.0mm bore... a 1500 is 86.4mm bore.
1300 is 55.5mm stroke crank, 1500 is 63.9mm stoke crank, and the conrods are correspondingy different lengths.......
a 1300 crank in a 1500 block with 1300 rods and pistons will have the tops of the pistons not making it to the top of the bore by several mm, hardly acceptable.
If the aux shaft bearing are missing, then the distributor drive gear bush probably needs to be fitted as well, as this is how a "bare" block comes, devoid of all these parts.
SteveC
Checkout my ebay sotre....
http://stores.ebay.com.au/The-Fiat-Factory
