Car has been sitting for over 10 years. i pulled the engine re sealed everything and replaced most parts that would be regular maintnace. i have the intake off and fuel coming out of #4 injector but not the other 3 and when tested there is always power on the connector even when cranking, is this normal? secondly i have an eletronic ignition that is getting no spark. i have a new coil wires cap and rotor. what controls spark and fuel injection and is it the same unit? my noid lights dont flash, do they usually? i dont see a crank or cam sensor, how do these engines no what position they are in ( is it the modual)
-for the fuel if there is always power i am guessing that i will just need 3 new injectors?
- tested the pick up coil with an ohm meter and it has continuity
-:bang::bang::bang::bang:
