Unfortunately my x19 is turning out to be the money pit. I did the struts, brakes, calipers, lines and now after I am able to drive it, it appears to have a fluid leak by the inspection cover by the mounting bracket of the flywheel. I really cant tell if it is oil or differential fluid. I open the differenttial fluid and it is still open and I cant really tell if it is oil. When running the engine at idle it does not appears to leak. It must happen when driving. It is a definite leak and I noticed a small round area where the fluid dispurses under the engine. Today I noticed it by finding a few drops on the bottom of the two bolt that bolt the tranny/engine mount to the chassis. I took this bracket off and that is when I discovered it gives access to the plate that you can bend open where you see the flywheel. Any thoughts will be greatly apprecaited. On top of all of this the starter is failing and I need a master cylinder. I am trying to figure out if I should cut my losses and sell it now or fix the leak but I am worried it may be a very big project. Thank you.
