jimbro1000
Established member
It all depends on your interpretation of the "worst" aerodynamic problem.
The breaking pressure wave and low pressure area behind the buttress causes a lot of drag and a bit of lift but this is just slowing the car down.
The problem of major lift at the front end would result in the car taking off - at 170mph it would launch very nicely and once you got the front end high enough it would go skyward at a fair velocity (think Mercedes taking off down the Mulsanne Straight).
Unfortunately I have quite strict rules about what I can do to the car in silhouette. I'm allowed a rear spoiler - single chord limited to a vertical dimension half that of the rear window - not very big then but it just happens to be the same as the rear spoilers used by F3 cars of that era, so you can guess what I have on the back of the car. That is about all of the changes I am allowed though. I have a concession to run an Abarth periscope since these were from a recognised variation of the X1/9 and there was a fully street legal version (just one unfortunately). It might be a bit of mix and match but it means I can make the most of it. What it does mean though is no extra attachments for stabilising the air flow from the roof or preventing flow detachment. The original plan was to partially cover the gap behind the buttress so limit the vortex but the angle from the roof is so large that it wouldn't make much difference and would only further reduce rear visibility.
