Nello
Established member
My 1300 is currently SORN and has done very little mileage over the past couple of years (sub 100 to be precise!) I start it monthly and run every couple.
Noticed last time I ran it that although the car reaches normal temp gauge reading and runs fine theres no heat from the heater? I'm sure the previous time it ran it was fine? As the gauge indicates normal reading I'm presuming the Thermostat is ok..... Temp heater blockage perhaps? I'll see what happens next start but is there anything notable that could cause this? Hopefully a heat cycle will cure any blockage......
