![]() | #1 | ||
Posts: 171 Thanks: 5 Trader Rating: 0 ![]() | Brake fluid reservoir cracked Hi all, I've just noticed that the top of my brake fluid reservoir is cracked, probably due to aging. Any ideas on where I can find a replacement? This seems to be a rare item... ![]() X1/9 parts are usually carry-over from other models, but I can't find the part number listed anywhere. Is FIAT P/N 4394454 the correct P/N?
![]() | #2 |
Posts: 1,914 Thanks: 107 Trader Rating: 2 ![]() | Re: Brake fluid reservoir cracked I don't know about the original parts but similar parts are readily available for motorsport purposes. Try somewhere like Tilton: http://www.tiltonracing.com/content.php?page=listb or Demon Tweeks: http://www.demon-tweeks.co.uk/Motors...eservoirs/1717
__________________ 09 Abarth 500 first 200 launch edition |
![]() | #3 | ||
Posts: 171 Thanks: 5 Trader Rating: 0 ![]() | Re: Brake fluid reservoir cracked Just to share some information, early X1/9s (1974-75) had two brake fluid reservoirs taken from the 132 model(?). Part number is 4362541, and they appear in the catalog from "autogamma": http://www.autogamma.com/pdf/catalog...id%20tanks.pdf The down side is that you lose the low brake fluid level warning light, but it's a possibility. Take a look here to see how it looks (download pdf file 74_75_chassis.pdf) http://www.midwesternmedicalmachine.com/~damonfg/
![]() | #4 | ||
Posts: 171 Thanks: 5 Trader Rating: 0 ![]() | Re: Brake fluid reservoir cracked Given the space available almost any reservoir will fit. I was however trying to retain some originality. By the way, the two reservoirs used in the early cars are the same as the clutch reservoir used in later cars, so if anyone is looking for one....
![]() | #5 |
Posts: 1,914 Thanks: 107 Trader Rating: 2 ![]() | Re: Brake fluid reservoir cracked If the reservoirs are of a suitable depth and have the same thread size for the cap then the low level light is irrelevant as it is incorporated in the cap not the reservoir itself. With a bit of work almost any suitable sized cap can be used to get the indicator, it just takes some mix and match work...
![]() | #6 | ||
Posts: 104 Thanks: 4 Trader Rating: 0 ![]() | Re: Brake fluid reservoir cracked The stock brake reservoir cap will fit the clutch one. Using 2 clutch reservoirs will give you the added bonus of separating the front a rear brakes completely so if the fronts leak the rears will still work and visa versa (or this is my understanding from what i've read elsewhere) Bear in mind that you would probably need 2 indicators caps wired in parallel so that if either dropped below level the dash light would come on twin clutch for brake reservoir is described here http://xwebforums.org/showthread.php?t=7751 Hope this helps Cheers
![]() | #7 | ||
Posts: 171 Thanks: 5 Trader Rating: 0 ![]() | Re: Brake fluid reservoir cracked I think I'm going for the twin clutch reservoir solution. These are still available and allow for the level indicator as seen here: ![]() This is the setup used in early FIAT 127s. The clutch reservoir is easier to find under "LADA 2101-1602560". I believe this model was still being produced early this morning...
![]() | #8 | ||
Posts: 29 Thanks: 5 Trader Rating: 0 ![]() | Re: Brake fluid reservoir cracked Hi all, I've just noticed that the top of my brake fluid reservoir is cracked, probably due to aging. Any ideas on where I can find a replacement? This seems to be a rare item... ![]() X1/9 parts are usually carry-over from other models, but I can't find the part number listed anywhere. Is FIAT P/N 4394454 the correct P/N? 1) if the cracks aren't too serious, they can be "welded" with a soldering iron and a piece of scrap plastic to use as welding rod. I've done that a few times. 2) although the brake reservoir is no longer available, the smaller clutch reservoir is, and you can use two of them in place of the single two-tank brake reservoir. Indeed, that was the stock configuration in the earliest cars. 3) try searching the archives over at xwebforums to find which BMW parts can be substituted.
![]() | #9 | ||
Posts: 171 Thanks: 5 Trader Rating: 0 ![]() | Re: Brake fluid reservoir cracked I've just received a couple of clutch reservoirs from my local LADA dealer! Top marks for the LADA service, although I fail to understand why they have a "local" (in Portugal) parts dealer when they don't sell any cars here. Anyway, as expected, these are the "autogamma" parts, identical to the original FIAT items. I'll have to dig up a new cap with sensor, but that should be easy to find.
![]() | fracture4 | Punto (Mk2/2b) | 4 | 11-10-2009 15:39 |
![]() | MikeSalt | Punto (Mk2/2b) | 1 | 02-06-2009 16:50 |
![]() | digger58 | X1/9 | 4 | 15-04-2009 20:54 |
![]() | oagra | Punto (Mk2/2b) | 2 | 21-10-2008 14:13 |
![]() | MikeSalt | Punto (Mk2/2b) | 7 | 23-07-2008 03:00 |
