Hello,
I am installing twin 40 DCNF's on my 1500. If anyone has done this before, I would like to know which jets and venturi you finally settled with so I can use them as my base-line.
I am also using IAP's "Autocross" cam (42-82 82-42) Lift 10.6, but I'd appreciate any numbers for a 1500 regardless of camshaft.
I noticed on another forum for X-1/9 racers that using a single 40DCNF is a popular modification from the progressive two barrel, and some may think it excessive to use two, but I used to run twin 40 IDF's on my 1438cc 124 coupe, and I liked it quite a bit.
Thanks.
Thanks.
