Dogdda
This is an extension of my input into the Coolant Question Thread. If you have read the aforementioned thread, you will know that I am pulling my hair out trying to get coolant through my heater.
I have already changed the heater valve for a new unit and checked good flow through the matrix.
Through a lot of fiddling, I have had some small success, but the problem is nowhere near solved.
Today I removed the water pump to check clearance of the impeller on the housing. and I did find a large clump of junk blocking the spigot for the heater connection. So that is where SOME of the problem is solved.
Now for my confusion. In the process of cleaning the pump housing, in particular the heater spigot flange area, I found that there are no water ports or passages in the pump housing for water to enter the spigot! The spigot also has a take off pipe(small diameter) that leads to the carbie for the choke. The other pipe on the choke discharges to the thermostat housing.
Haynes tells me that water flows "from the water pump to the heater and returns to the water manifold". This seems to be true due to the choke pipes mentioned above. If there are no ports or passgaes, HOW DOES THIS HAPPEN? I am not a degree qualified engineer, nor am I a mechanical dunce. The construction of the housing suggests that if i drilled a port straight through, the opening would be on the suction side of the pump, thereby putting lie to the Haynes description.
Maybe if the Haynes had a diagram of the cooling system I might nut this out. Does ANYONE have such a diagram?
Should I drill or is it supposed to cast this way?
AAAAAHHHHHHHHHH!!:bang:
