Thread Tools
Old 25-01-2010   #1
USA
gas tank removal
so i have a 1977 x1/9 and im trying to remove the gas tank. and i cant seem to figure it out. i think its supposed to come out from behind the drivers seat but i cant figure it out. please help
thanks
-D
dbith57 is offline Reply With Quote Quote
Old 25-01-2010   #2
Trader Rating: 2
Re: gas tank removal
The procedure is approximately this (assuming the tank is drained of fuel already):
In the engine compartment release the two fuel lines from the tank.
Unplug the fuel sender
Remove the rubber firewall seal/grommet that the fuel lines go through
Disconnect the fuel filler pipe and vent
Jack the car up - as high as you can at the rear
Support the fuel tank from below
Carefully release the two straps that support the tank
Lower the tank down
The point to be very careful of is when you remove those straps - if there is any corrosion the odds are that the straps will take some of the tank with them and you'll end up with a perforated tank. To a degree this may be unavoidable but you can minimise the damage by being careful. Given the likelihood of this you'll probably have to reseal the tank regardless.
The less significant point but almost as important is the fuel sender and pickup - be extra careful when removing this as the studs on the tank can shear off very easily, you also need to treat the seal with kid gloves.
Thanks dbith57 thanked for this post
09 Abarth 500 first 200 launch edition
jimbro1000 is offline Reply With Quote Quote
Old 25-01-2010   #3
In a quandry!
H105Daz has donated!
Another handy tip is when you drop the tank, it seems the natural course is 'bottom towards front of the car' but actually comes out better if you direct the falling tank toward the rear of the car and it just slides out perfick!
CHEERS DAZ
H105Daz is offline Reply With Quote Quote
Thread Tools
(G) uno 45S gas tank cap wont open adamot Uno 1 28-10-2009 08:27
$25 million prize for greenhouse gas removal mountainmachine Leisure Lounge 14 09-02-2007 17:57
(T) How do i empty the gas tank on my fiorino Jallizz Fiorino (Mk1 / Mk2) 10 09-06-2006 23:33
(T) Gas tank ID Kickstarter 124 Spider (Classic) 3 12-05-2006 05:23
(T) Removing Gas Tank Warp X1/9 3 02-08-2004 01:42
