leos mr fixit
Hi All, Has anyone here ever fitted an aftermarket fuel pump in place of the mechanical one? Ours is not long for this world (noisy) Any advice appreciated..
The other trick I recall from X1/9OC IcsUnoNove magazine back in the late 80's was a method of running the power for the electric fuel pump via a connection to the oil pressure warning light circuit.
Working with a relay so that the electric fuel pump only gets electrical power when the engine oil pressure is high enough for the oil warning light to be out.
The idea of this being when your engine is not running but the ignition is still on the electric fuel pump is not whirring away pushing fuel past the carbs float chamber valve.....
However considering how the in-tank electric fuel pump on our '93 Uno 1.0ie works...As soon as the iginition is on it constantly pressurizes the fuel lines...
I guess the presence of the return pipe from the x1/9's carb means that you don't necessarily need to do what X1/9OC IcsUnoNove magazine suggested over 20 years ago
