1. what do I do with the fuel line that goes back to the tank?
The carburettor setup should have a fuel return on it for the standard setup (if you go that way) or from the fuel pressure regulator if you need one for an alternative setup
2. Do I plug the line that comes from the back side of the block or is that where I need to put a PVC valve?
Not sure on the PVC bit - on european cars, if I've read this right, it would just feed into the air filter box to recirculate crank vapours into induction system and perhaps more importantly create a slight vacuum in the sump cavity.
3. The wiring where the fuel relays where at, I dont need those anymore/I wont be using them?
If you have the big multi-pin fuel control relay, don't throw it away, there are people who will rip your arm off to get one. You will however need something to drive your fuel pump unless you go for a mechanical pump driven from the water pump pulley via a short camshaft (not recommended - the mechanical pumps are marginal for anything beyond completely stock).
4. Is there a kit for the carb linkage? and where can i get it?
Good question - yes and I don't know respectively. linkage kits tend to be generic and require a bit of adaptation
5. The low pressure fuel pump, will that be run through a relay?
See my answer to (3)
6. And if so,where do I hook the relay too?
The pump needs to powered from the "run" stage of your ignition circuit (same as the coil would be if you had one). It is a good idea to get a cut-out safety in the circuit too - all new fuel injected cars are required to have one now to stop fuel in the event of a roll over or impact.
