Old 28-02-2009   #1
gear oil ?
hi, anyone know if i can use ep gear oil in my fiat x19 as thats the only one i can get hold of... manual says not ep.. thankyou
kikbak66 is offline Reply With Quote Quote
Old 28-02-2009   #2
Moderator
Peter Pick-Up has donated!
Russia
Re: gear oil ?
www.castrol.co.uk
"what oil for my car"
Thanks kikbak66 thanked for this post
Peter Pick-Up is offline Reply With Quote Quote
Old 28-02-2009   #3
Re: gear oil ?
Thanks Peter, massive help,found cure to the problem as well as this site i found another site which was also very helpful www.opieoils.co.uk. The answer seems to be epx or a castrol multigrade. Thanks again.
Old 28-02-2009   #4
Moderator
Russia
Re: gear oil ?
Castrol and Fiat go very well together, it's the only oil I use for many years now.
Old 28-02-2009   #5
Trader Rating: 2
Re: gear oil ?
Never, ever use EP oil in your X1/9 gearbox. The gears aren't suitably treated and will just disintegrate (putting it simply).
Use a regular 80W90 gear oil as a basic preference, Redline MT90 is my personal favourite.
09 Abarth 500 first 200 launch edition
jimbro1000 is offline Reply With Quote Quote
Old 01-03-2009   #6
Re: gear oil ?
Quote Originally Posted by kikbak66 View Post
No! NO! NO!
Do not put EP gear oil in your X1/9 - it will trash it! I know from experience. Had 4 X1/9's, 1300 and 1500 and one thing I strongly remember is rebuilding a 1500 X1/9 gearbox after it was filled 'accidentally' with EP oil; to do such a rebuild now would cost more than buying another car.
The reason: EP (extreme pressure) oils in gearboxes designed for non-EP oils find that the oil forms too thick/strong a layer in all the contact surfaces and so effectively forces all the internal components to have less space and so they work against each other and, ironically+unfortunately, work to destroy each other.
Conversly, if your gearbox is designed for EP oil (not an X1/9) then to not use such an oil would also cause excessive wear due to lack of sufficient inter-metal protection.
Hppe that helps and enjoy your X1/9 - great cars, just keep it in a garage and away from water. ;-)
RichardBradford is offline Reply With Quote Quote
Old 01-03-2009   #7
Re: gear oil ?
Thanx all,,,,, its amazing how many people that sell oil haven't got a clue...... drove round looking for oil, and two shops said " it will be fine to run EP its for all cars" thankfully I new better.... thanx guys..................
Old 23-09-2009   #8
Re: gear oil ?
Hi Guys, just been reading this thread, the gearbox in my x1/9 leaks a bit of oil and I have been topping up with Castrol EPX 80w90, is this OK? The gearbox synchro is a little weak in third and shot in first but other than that is ok, I want to try and put off rebuilding it for a year or so (need the money to sort the body work!) and hence want to make sure that I am filling it up with the correct oil!
gb804520 is offline Reply With Quote Quote
Old 24-09-2009   #9
Trader Rating: 2
Re: gear oil ?
Any ordinary EP oil (including Castrol EPX) can do an incredible amount of damage to the gearbox internals on your X1/9. Sadly there are few non-EP oils around these days so you have to do a bit of digging.
Castrol ST90 would be ideal if you had to use Castrol.
If the box is leaking you may want to find some additives to help as it is normally down to dried out seals that can be revived with proper treatment.
Old 24-09-2009   #10
Re: gear oil ?
if your struggling finding someone with none ep oil, find a motorbike or at a preference a scooter shop and ask for some SAE90 (straight 90) as whats in the engine of a lambretta (not vespa thats SAE30.)
Lammy oil is whats in mine now and its stopped cruching in 3rd now :-)
gb804520, i always though exxey's never had a synchro in first till i was told otherwise :-)
BTW Jimbro, if it does crunch in 1st and 3rd, how long do you think it would take to prop the 'box, change the busted synchro's and re fit it? a weekend of a job?
littlephil is offline Reply With Quote Quote
Old 25-09-2009   #11
Trader Rating: 2
Re: gear oil ?
If it is just 1st and 3rd you might conceivably get it done in a weekend but don't put any bets on it.
It isn't that it is a particularly difficult job, just time consuming to do it all right but if you have the workshop space and the tools then it is do-able.
Old 25-09-2009   #12
Re: gear oil ?
Hi Guys,
Thanks very much for the quick reply, I visited a couple of local motor factors today who all tried to sell me EP oils! Anyway now ordered some Redline MT90 online so will change the oil as soon as it arrives.
I may have ago at the gearbox myself, I am happy pulling engines etc apart but have always steered clear of gearbox's maybe I need to face my fears!!!
anyway cheers once again
Thanks leos mr fixit thanked for this post
(G) Gearbox oil. ep 80w/90 hypoid gear oil? sassbs Bravo / Brava 1 21-04-2008 09:36
(G) Engine Oil, Gear Box Oil, Fan / Engine Coolant? 1.2puntosporting Punto (Mk2/2b) 2 30-05-2007 23:13
(G) gear oil flytibet Panda (Classic) 0 25-02-2007 17:34
(T) gear oil MintySport Cinquecento / Seicento 4 03-08-2005 10:14
(G) gear oil 4dog Uno 1 25-02-2004 23:08
