Thread Tools
Old 31-07-2004   #1
Removing Gas Tank
I think I need to clean out the gas tank and I wonder if someone
who has done this (recently) could tell me the best way to attack the problem? I know the car has to be r4aised quite a ways ( no lift in sight). Is it likely I can jack the car up high enough from the left
side to lower the tank out?
TIA
Mark
Warp is offline Reply With Quote Quote
Old 01-08-2004   #2
That is the only way to get the tank out....
I have done this a few times and it is easier than I first thought. It is a lot easier to do with the tank empty...
If the car is driving, drive it up on ramps... both on the left side.
Remove the fuel line and sending unit connections from the top.
Raise the left side of the car almost 2.5 to 3 feet off the ground.
Remove the straps and slowly lower the tank...
The tank leans top towards the rear of the car and it helps to move the bottom of the tank towards the front of the vehicle as you are lowering it...
Very easy... just remember to be SAFE!!! the car is not very stable lifted like this.... you know how well the E-brake works....
Later Daze,
Eric Flowers:D
1980 X1/9 His
1984 X1/9 Her's
"Real men love hugging tight curves"[}:)]
Mr. X is offline Reply With Quote Quote
Old 01-08-2004   #3
Thanks for the help Eric. Last time I pulled an X1/9 tank was
'84 I think when I was building my race car and I think I raised
it from the back with ( a big no no ) blocks on top of the jack.
Mark
Old 02-08-2004   #4
No biggie... If you were close to Houston, I would drive over and help ya out.... I have been doing a lot of that as of late....
Later Daze,
Eric Flowers:D
1980 X1/9 His
1984 X1/9 Her's
Thread Tools
(G) Fuel tank filler vent blocked and cut outs Mazz0 Uno 9 22-07-2015 09:44
Petrol tank !!!!! duffcinq Lets Talk FIAT 4 01-08-2005 21:22
(T) Fuel tank breather Bogul Punto (Mk2/2b) 5 02-06-2004 02:14
fuel tank leaking on my Punto IainB Lets Talk FIAT 10 10-02-2004 16:03
(G) is it the fuel pump or a blocked tank vent.. lashlondon Uno 8 24-09-2003 21:58
