Thread Tools
Old 30-11-2007   #1
Anyone fitted an electronic ignition to the Xy
If so then what was the cost and did it make any difference at all?
Considering doing this to mine, but only if it will be worth it.
bigfatbloke71 is offline Reply With Quote Quote
Old 03-12-2007   #2
Trader Rating: 2
Re: Anyone fitted an electronic ignition to the Xy
Definitely an improvement but a pig to set up in some cases. The benefits are limited to how well the mechanical advance mechanism works in your distributor unless you opt for a mapped system without a distributor.
Simplest option is an electronic ignition setup from a 1300 Uno (non-turbo). All you have to do is swap the X1/9 shaft over to the Uno distributor head (otherwise it is too long and wont fit in the engine bay) and bolt the whole thing in complete with wiring and module.
I wish I'd know about this when I did mine - I went for a lumenition optronic system (at relatively great expense). A very good setup all the same though so I shouldn't complain from that aspect.
09 Abarth 500 first 200 launch edition
jimbro1000 is offline Reply With Quote Quote
Old 03-12-2007   #3
Thanks again Jim
BTW, do you know if the clutch hose is the same size as the rear brake hose
I am trying to find a clutch hose as mine is looking worse for wear. I have a spare rear hose. It is a Goodridge in Orange, but don't want to try to swap them without knowing if it will fit.
Kev
Old 04-12-2007   #4
Trader Rating: 2
I don't know the answer to that one and without a car to hand to check I wouldn't want to guess
Old 09-12-2007   #5
The brake line is not the same
Does anyone know if the Dizzy from an 1138 Uno is the same as the 1300
Thread Tools
(T) Electronic Ignition Conversion 852421 X1/9 5 01-04-2008 17:03
(T) no spark in electronic ignition samantha Bravo / Brava 2 26-02-2006 15:51
(G) Electronic Ignition Thingy Sprox Panda (Classic) 39 22-02-2006 11:46
(T) That's more like it ...........1242 now fitted minijohn Cinquecento / Seicento 19 09-09-2005 20:33
(T) Ignition cuts out :-( quater Punto (Mk2/2b) 2 10-05-2004 22:59
