OK, here's a ridiculously-technical question but one which will change the course of my day tomorrow (putting my Uno Turbo back together)...
I've done a floor-renovation (yes, to fix rust at the edges of the floor) and this includes stripping out the cracked sound-deadening pads (to be replaced). Some of the underlay-felt was also soaked, not helping matters...
There are numerous 'tabs' on the Uno floor that form drains in the footwells. These are covered over by the factory, when the deadening pads are stuck down, and they don't attempt to open them.
In the past on other Unos I've usually cut slits etc. to open the drains. However on my Uno Turbo, someone has actually removed some of the deadening and then sealed the drains with silicone - but only at the back of the driver's footwell!
So - the question - is it better to have the drains, or to seal them up? Is there a greater risk of water coming in than of airflow/moisture out? I just can't decide, but I'm sure, with the more severe conditions in the UK, that someone will know for certain
Thanks!
-Alex
Thanks!
-Alex
