(CZ)enda said:
We understand 'comealong' too
I think it's an American term.
However, the dark side of my day is that the Citroen mode reports a fatal error (i.e. the bugger will not start. I wonder why I bother to pay insurance for this French parody of engineering. It was offered to be sold for the price of its exhaust piping. I do not want to see it again.).
LOL...
:worship: You have a fantastic way with words... 'a fatal error' indeed! (As I drove off in my Stilo today, there was a BING - ABS Failure - BING - ASR Failure - BING - ESP Failure - RETURN TO DEALER... like hell I will
All these disappeared on the next restart...)
The bright side is that I have just passed 1,4 Tipo for silly money and agreed a lookover for tomorrow. The body seems OKish... for a 1991 car. AFAIK Tipo is only a bit bigger Uno, aint it?
Good choice for a simple, dependable car that won't rust away.
It is in fact very different to an Uno... body and construction, suspension, trim parts, even brakes totally different. (edit: I see that I've now spent over an hour justifying this statement
Although engine & gearbox are familiar (the same as Mk2 Uno 70)... the styling is different in every way though you will no doubt find that people confuse it with an Uno!
Driveability problems can be quickly remedied by fixing air leaks - at the small rubber pipes and particularly the rubber carburettor mounting base (which splits). So don't be put off if your test drive proves near-impossible to conduct smoothly
Ignition system is very good on 1.6 models (big ECU, crank sensor etc.), not so good on 1.4 models (similar to the Uno with the wretched distributor finned module - carry a spare...)
Gearboxes are much stronger than the Uno and often quite heavy/clunky to shift (my Uno Turbo has one of these Tipo boxes, and I've improved it by flushing and filling with thinner oil).
The Tipo is almost completely galvanised, so rust is not usually a problem (though, I have heard of a rust hole in the roof and the floor). Usual areas like doors, windscreen base etc. are NOT a problem.
The bodyshell is much more rigid - and larger - being a replacement for the Strada/Ritmo-128 rather than the 127 replacement that the Uno is. It feels like a much bigger car to drive, and it does weigh just over 1000kg. Many say that the handling is better than the Uno. I'm not certain... it drives like any other newer car... a 1991 Tipo will feel ten years newer than a 1991 Uno... softer ride, less shakes and fewer rattles definitely... and did I mention, no rust
Be on the lookout for suspension wear problems common to the Uno - that is, lower arm balljoints (steering wobbles/pulls with engine power), worn shock absorbers. Take the price of an Uno part and multiply by 1.7 to get the Tipo part price. Take the time required for the job, and the number of different-sized spanners, and multiply by 2...
Styling is not as 'clean' as the Uno (styled by I.D.E.A, better known for furniture and appliances?), having a rather slab-like and strangely-proportioned shape.
Electrics can be a little hit-and-miss with the Tipo, though I feel that they are better than the Uno... none of these cars has ever given me much grief, but certainly the rear wiper of the Tipo and its central locking are both very common failures (the rear wiper can be taken apart and fixed, but the central locking is best remedied by fitting new lock motors in parallel to the originals). Heater fan resistor has a temp. cutout that fails (not the resistor itself...) and can be bypassed, still giving all four speeds... Simple things like the windscreen washer can prove a surprising challenge (motor that runs in two directions with breakable outlets), and again, remember that parts are relatively expensive compared with the Uno. I also enjoy fixing the digital dashboards (could go on for hours)...
(Off he goes to spend a night reading a Tipo manual....
There are some truly obscure devices, like the vacuum-operated accelerator pump which is cut off when the engine is cold, making acceleration quite the wrong word to use, and the electric intake manifold heater (a short in its haphazard wiring will cause the melting relay to drop out onto your accelerator pedal foot - RHD versions at least). Also, the heater depends on a water valve (like the Uno) and the crude non-bypass design of the thermostat means that on a cold start, all the coolant tries to pass through the heater (which might be closed) - so it's normal for there to be all sorts of strange gurgling noises as the engine revs increase.
I would say, if looking for economical backup transport (with enough room in the back to double-up as a van - large tables and fridges go in no problem), a basic 1.4 Tipo without central locking, electric windows, or digital dash, would be best. I think these all have manual steering. They are a little noisier than the more deluxe 1.6 models, and obviously not quite as luxurious (Tipo power steering is a big improvement over the manual system, and the more upmarket interiors are a lot more plush, thicker seats, proper carpet, more soundproofing, etc.) However, the 1.4 is not really any slower than the 1.6 (due to the extra weight of all those luxuries) and there will definitely be less to go wrong. If, like for me, the thought of things going wrong is only a minor challenge, then go for the 1.6 - a much nicer car to ride in for the same money now as a 1.4
I sold my Tipo (1989 1.6 DGT) in 2001 because it was too boring (there was nothing that needed fixing), too expensive, and not fast enough (good handling or not, I found it more sluggish than my Uno 60 (0-100km/h in 18 seconds) and couldn't quite get to 160km/h...) I replaced it with a FIAT Croma 2.0 i.e. - a lot more interesting... and then with a Lancia Thema V6 that was just the ultimate
I've since worked on four different Tipos. More recently I owned a basic 1990 1.4 Tipo for a few months (selling on behalf of a friend). It had normal dials that could be read even in sunlight - I missed the exciting green LCDs of the DGT. It still seemed slow, but no slower than the previously-mentioned 1.6 - felt pretty utilitarian with the van-like non-power steering, but a bit faster and better all round than a basic Uno 45. (I hope Chas hasn't read this far!)
-Alex
