Oh dear, I just found yet another Haynes manual 'anomaly'...
Wiring diagram 14 is the one you need - 'tachometer, digital clock, map reading lamp and vacuum gauge (Comfort, ES, S and SX models)'.
Sadly, it's exactly the same as diagram 11... showing a clock in the instrument panel (7460) - HOWEVER *newsflash* it looks like there is an unlabelled four-pin connector (exciting!) which has the following wires (and in this order):
N - black - this is earth (easy)
M - brown - this is +12v all the time. It's connected to the lighter socket and the supply for the radio.
GR - yellow/red - this is the instrument lighting. You can pick it up at the lighter socket or at the small bulb holder behind the heater controls.
L - light-blue - from the heater fan switch. This is +12v when the ignition is on (I usually tap into the same wire at the heater fan switch for installing a stereo with an 'ACC' wire).
This connector is shown on the right of the diagram, next to 'radio' (one wire found in the radio slot - what a joke - has anyone ever seen a one-wire radio?! Strictly a case of DIY with the Mk1 Uno, as they provided no speaker wiring, and not even an earth...)
So if you can't find the four-pin connector (near the fusebox I think), there's where to connect your own wires to. Again, don't be misled by the part 07460 labelled 'Clock', that's the one in the instrument panel which you don't have any more. Also, take a look inside the clock unit - the pin that goes to the 'common' part of the circuit and one pin of the bulb, is the earth. (An interesting project for you?)
I've attached a scan, complete with my writing to identify the parts. Sorry to anyone that thinks manuals shouldn't be written on, but trying to look up part number after part number drives you mad after a while...
Welcome to the joy of Italian Wiring. This is a relatively simple car, but for the Mk1 Uno there are 29 diagrams, and 22 for the Mk2, though various mysteries, such as the Automatic Temperature Control heater, are not covered.
I remember someone on the Alfa 164 forum asked for the wiring diagram for some of the hidden relays behind the instrument cluster. The answer from the resident expert was, "just what circuit do you want? The wiring diagrams for the 164 run to 600 pages".
600 pages! Just imagine what the Stilo Abarth wiring is like... Though I understand it uses CAN-bus (multiplexing) so that probably cuts it down a bit.
-Alex
PS. The interior roof light is shown as having BR (white/red) and BN (white/black) wires. I've seen at least two Unos where one of the wires was white, and the light itself is labelled 'Bianco'. Why? Well, perhaps they ran out of the striped wires and carried on making the looms anyway. You really CANNOT rely on wiring diagrams with Italian wiring...
