Old 28-03-2006   #1
Trader Rating: 1
Vacum advance
Hi Guys
I checked my vacum advance last night and found there was no resistance to me sucking or blowing.
The car runs fine and ticks over nicely.
What are the downsides to having a leaking unit?
I am hoping to get another uno for spares and so will transplant this unit soon.
Pete
Peterg is offline Reply With Quote Quote
Old 28-03-2006   #2
Chas Uno has donated!
Air Dodge Champion, Asteroids2000 Champion, Frogger Champion
Re: Vacum advance
Quote Originally Posted by Peterg
Hi Guys
Pete
Hi Pete,
A failed vacuum advance will make the engine run on the weak side, as with no resistance from the vacuum unit the carburetor will draw extra air in from the connecting pipe. More air = weaker mixture.
Normal symtoms for a failed unit are poor tickover, stalling and hesitation when accelerating. Your distributer also won't be giving the correct advance/ retard settings for the ignition.
If you've got access to a timing light, check the timing. If the timing is set correctly (vacuum advance pipe disconnected and plugged), the engine will tick over roughly. Once the pipe is reconnected, the correct advance/ retard settings come into play and the engine will tick over much more smoothly.
It is possible to get the engine to tickover ok with a failed vacuum unit, but the only way to do this is to adjust the distributer until it runs smoothly. This is ok at tickover, but the ignition settings will be out as soon as you rev the engine.
They're not expensive, so for peace of mind fit a new one, or one from your spares car
Chas Uno is offline Reply With Quote Quote
Old 28-03-2006   #3
Shut Up, Fool!
thepottleflump's Avatar
thepottleflump has donated!
Re: Vacum advance
I think they cost about 10 from shop4parts
1999 Alfa Romeo GTV V6
thepottleflump is offline Reply With Quote Quote
Old 28-03-2006   #4
Trader Rating: 1
Re: Vacum advance
Thanks for that pal, do u know if I can swap one from a 93 1.0 ie or do they have different settings?
Pete
Old 29-03-2006   #5
Trader Rating: 1
Re: Vacum advance
Can anyone tell me how much resistance the unit should give and is it while sucking and blowing?
Pete
Old 29-03-2006   #6
Yugoslavia
Re: Vacum advance
Pete
- almost full resistance on sucking
- very small resistance on blowing
No pain no gain
dekii is offline Reply With Quote Quote
Old 29-03-2006   #7
Trader Rating: 1
Re: Vacum advance
Thanks.
I had ago today swapping over the unit and could not see how the plastic shaft that extends from the unit into the dizzy releases.
Any advice appreciated.
Pete
Old 29-03-2006   #8
Trader Rating: 1
Re: Vacum advance
Just done this job tonight, i managed to snap the plastic arm off when removing my old unit, then i had to fish out the other bit. I did this by sticking a large screw-driver in and forcing it but then that broke it so perhaps not the best method but it works !
Took ages to get it to fit, until i made the hole on the plastic end slightly larger with a 4mm drill and it slotted in fine and works a treat
SuperUno is offline Reply With Quote Quote
Old 30-03-2006   #9
Trader Rating: 1
Re: Vacum advance
Yes your right had ago myself but found that the plastic shaft looked like it was about to snap so I held back, I may try and swap a whole unit including the dizzy if I get hold of one.
P
Old 31-03-2006   #10
Trader Rating: 1
alexGS has donated!
New Zealand
Re: Vacum advance
Yeah, you push a screwdriver into the slot until it releases. I haven't had one snap yet - it's made of super-plastic
Putting the new one on can be a little fiddly, but a screwdriver pushed into the slot (again) and maybe twisted a little, and another screwdriver prying upwards, and it should pop on fairly easily. I wouldn't enlarge the hole personally, I think it's good if it doesn't come off too easily...
-Alex
'15 Giulietta 1.4MA, 14 Abarth 500C Esseesse, '08 500 Lounge 1.4 Dualogic, '08 G Spyder, '71 850 Coupe in bits...
alexGS is offline Reply With Quote Quote
Old 31-03-2006   #11
Trader Rating: 1
Re: Vacum advance
Thanks Alex
Knew you would have invaluable experience of this task.
Pete
(T) vacuum advance cm246 Uno 13 07-12-2015 12:24
(T) tipo vacum diagram rebel Tipo (Classic) 1 19-11-2005 16:13
Advance Notice: 2 Classic 500s on Ebay! topolinofan Auction Watch 4 03-11-2004 23:52
(G) UNO (999cc FIRE) vacuum advance question Sreenath B.H Uno 2 15-05-2004 21:01
(T) wont fire.fuel in vacum line? parkey Cinquecento / Seicento 8 08-12-2003 04:42
