alexGS said:The last time I looked, the 1108cc Uno had only a single-barrel carb
I think if you fit twin carburettors, you would need a camshaft change to notice much improvement.
-Alex
Luke1985 said:There was one particular variant of uno that had the twin choke carb though im sure of it maybe the old uno 60 - with teh 1116 engine?
M@nticore said:
you can just get an adaptor piece made to make that carb fit on the fire engine. I wanted to put a 1400 uno carb on, but didn't have the time yet.1986Uno45S said:
That looks excellent! Any more info on how it was achieved? I wonder if any more work was done on the engine to get the speedo running almost off the end?!!!!
Alex is right, it was only the older 1116cc non-FIRE ohc engine that had a twin choke Weber fitted (Uno 60S). The FIRE to my knowledge never had a twin choke carburetor fitted as standard.
It can be done, but you'll need to have a custom inlet manifold made up, plus possibly a custom throttle cable.
I have a twin choke Weber from a 1.3 Uno. Wonder how much work it would take to get it to fit my 1.0 litre FIRE? :chin:
KHALooD said:what about fitting 4 carbs?
any one tryed it b4?
Wonder how they did that converting an engine into a carb???,maybe I got the sentence all wrong.Oldschool said:Have done it to the race Panda. We used 2 twin 36 Weber downdraught carbs on the 1242. But they need to be down throated a bit.
Forget motor bike carbs. They are too difficult to set up and you won't find a lot of people who can do it.
A few people have converted FIRE engines to twin choke carbs.
M@nticore said:Wonder how they did that converting an engine into a carb???,maybe I got the sentence all wrong.
thepottleflump said:Would adding twin carbs be to increase fueling?
