Old 02-09-2021   #1
South Africa
Fuel pump oil leak
Hi guys,
New here. I have heavy oil leak. Took the 1100 Uno to mech and he says it is the fuel pump that must be replaced. Can this be so? Must the whole pump be replaced? Is it not just the rubber seal where the pump screws onto the head that needs replacing? There is indeed oil coming out from there but do I have to replace the whole pump?I have no other probs with the fuel pump.
Also, is replacing right the lower ball joint a pain?
Thanks!
Unome is offline Reply With Quote Quote
Old 07-09-2021   #2
South Africa
Re: Fuel pump oil leak
Update
The fuel pump just needed a new gasket. That solved the problem. Saved $$$$$!
(T) Broken Fuel Pump Case is giving me an oil leak! Monacovjm 500 (Classic) 4 27-11-2019 23:46
(T) Fuel Leak Coming From High Pressure Fuel Pump Nbhad 500 20 13-06-2019 13:55
(G) Fuel Pump Leak Labman 500 (Classic) 13 29-04-2019 23:53
(T) MJ fuel leak from pump Louie Bee Panda 13 20-02-2016 15:25
(G) Fuel pump leak Wee Smurf Panda 19 15-12-2014 22:32
