im Axle Specialists
Old 2 Weeks Ago   #1
South Africa
choke floods cant start
hi hoping to get some good advice.
Uno 1100 weber carb 1992 model
once i use my choke,even on a minimum,it floods so much that i have to remove the plugs to clean.
if i dont clean it and drive it as is,the engine drives underpowered,till i clean the plugs.
its petrol on the plugs,not oil.
should it not have removed the excess petrol while driving for 30 mins?
thanks for suggestions
gnilrac is offline Reply With Quote Quote
Old 2 Weeks Ago   #2
Re: choke floods cant start
Quote Originally Posted by gnilrac View Post
How old are the spark plugs?
It leads ok?
Rotor arm?
Distributor cap?
Ignition coil?
Likes gnilrac liked this post
jackwhoo is offline Reply With Quote Quote
Old 2 Weeks Ago   #3
South Africa
spark plugs 2 months young
disytributor bought a year ago,cap and rotor in good condition
coil im not sure about
Thanks jackwhoo thanked for this post
Likes jackwhoo liked this post
Old 2 Weeks Ago   #4
South Africa
was hoping yud reply,lol
Old 2 Weeks Ago   #5
Don't clean the plugs with a wire brush .
Wire brush leaves tiny traces of metal on the plug causing bad spark.
Old 2 Weeks Ago   #6
How old is fuel in car?
Old 2 Weeks Ago   #7
South Africa
all recent
Old 2 Weeks Ago   #8
South Africa
i think i should just get new plugs and see if that remedies it?
Old 2 Weeks Ago   #9
If you have been using a wire brush new plugs would be a good idea.
If possible get ngk spark plugs
Old 1 Week Ago   #10
Hi All
it sounds to me like the arm that gives throttle offset it not connected so the choke blocks the flow but doesnt give any throttle opening to compensate.
or the choke butterfly is freely moving when it shouldnt, or the choke throttle unloader arm is not working.
yes new plugs would be good and dont clean with a wire brush, if you use a brake cleaner spray then it evapourates very quickly leaving the plug dry.
Tim
timmycm850 is offline Reply With Quote Quote
Old 1 Week Ago   #11
Or the float chamber is being over filled by the fuel valve not shutting off( assuming carb fed)
(G) Floods PiersCM Sedici 2 07-02-2014 13:44
Electric Choke vs. Manual Choke Dwangpow Tech Talk 2 01-06-2013 23:52
(T) Electric Choke vs. Manual Choke Dwangpow 124 Spider (Classic) 0 20-05-2013 06:23
Floods lkc (FS) FS General Chat / Banter 5 30-12-2012 22:54
(T) changing manual choke to automatic choke scottyy Panda (Classic) 3 12-01-2011 22:43
