General Uno Turbo Daily - Build Thread...
UK
Hi there guys
Note been here for a while, but back in the Uno fold!
So, here is what i brought, a Uno 60 with a Punto GT engine conversion.
I wasn't really looking for an Uno again, however this was absoultey mint! Never seen a welder, been waxoled religiously, was just too good to pass up...
Anyway, here are a few of pics of from the previous owner.
Pre conversion
Few pics showing how clean the chassis leg's were!
And a few of the conversion parts
And a few of the pics of how i brought it..
When i brought it, it had a few issues i wanted to sort, firstly a really unstable idle, and a few bits that i wanted to re-do to my spec. Firstly the fuel system...
This was how it come
Firstly, i got a Mk2 Uno Turbo fuel rail
So, cut off the fittings and TIG welded some AN6 Fittings on
I also changed out all the lines to 8mm nylon front to back
Next i needed to make up a mount for the FPR
Next up made up the lines and fitted
At the fuel tank end i replaced the original turbo tank with a baffled tank. The days of an undertank fuel pump are gone what with the invent of high flowing in-tank pumps
Old tank
Old vs new pump
New in-tank pump
And fitted
Next up was sorting a pet hate of mine, bad wiring...
Stuff like this
And after
Before
After
Next up was the engine loom, i wanted to clean up the engine bay, move the ECU and relays into the car and make it look clearner
Here was the loom before
Old plugs
Making a template of the original loom
Mid making
And done, lovely MIL spec connectors
ECU, Relays, Fuses, and Bar sensor moved into the car.
This was the location when i brought the car.
And after, tucked under the dash.
Sorted a few other bits while the dash was removed, fixing previous 'wiring'
Before
After
Also fitted central locking
Next changed a few other bits like the throttle cable as it was ropey..
Old and new
Next up was sorting the lack of any kind of ducting on the intercooler and oil cooler, seen the difference a well ducted design could make on my Supra so figured i would fabricate some up.
Before, you can see the gaps all around where the air would escape
TIG'd up some ducts from aluminium
Oil cooler
New ducts and stainless hardware
Next up i wanted to make an AFM mount as it was just floating about, so...
Picks up on original mounts
Also made up a cable mount
Also TIG'd up some new boost pipes to replace the original mishmash, also changed the filter to a stock air filter housing
Before
Making the new pipes up
ICV Spout
Swage the ends
Fitted and done
Last job was fitting a light grill i got from italy along with Mk2 Sideskirts
Right update 2!
First nice simple thing first, getting rid of my old knob as it was a bit blue for me..
Nice little carbon number to replace it
Next up was to put a proper Turbo boot on, this is the one that come with the car, looked great but prefered the turbo look
Weight of the stock metal boot
Weight of the new fibreglass turbo boot
And fitted
Much better!
Next up was fitting my new boost controller, using the original clock location
Perfect fit!
I still wanted the original digital dash boost gauge to work, so i used the original MAP from the Uno Turbo ECu with a 5V step down power source mounted to the back of the clocks
Cut down
And fitted
Next thing to replace was the original black carpet with a red turbo item
Stripped out and cleaned the floor and protected
Here you can see the original sills, the previous owner regularly waxoyld it and you can tell... no rust!
Now thats a carpet!
While fitting the carpet i decided to add the turbo door and rear cards along with electric windows.
This is how the cards were before...
First up was putting relays in each door, made up a little aluminium mount
All fitted and wired up
Turbo door cards, electric motors and rear cards fitted
Looking smart now..
Rear door cards
Last few bits was to make a mount for the boost solinoid
And also fit my new clutch slave as the old one started leaking.. new braided stainless line too...
Thats all for now folks!
Right update time!
First the Speedo stopped working! Looks like the original Sharp optical sensor had started to break down
IMG_5613
So replaced with a modern sensor, was very tricky!
Next up was a wheel change, got some Strada 14" Speedlines
IMG_5876
IMG_5875
This is how they come back
CF8F002E-745E-4518-938B-E3B708DCDA21
IMG_6094
Next up was to change the rad, i want a 50/50 split with the intercooler. I looked at a few options but in the end went with a 4 core 60mm thick Civic radiator.
So, here goes...
Stock rad
IMG_5946
As the radiator was rotated 90 degrees i needed to split the radiator flow path, so gap cut
IMG_5975
Plate slid into the gap
IMG_5976
Welded up
IMG_5980
Temp switch bung welded in
DF934471-16FE-4D3E-80BD-D6D6CB60A458
Mount added to top to connect to slam pannel
BCEBC23B-880A-44EB-B9C1-AAC557611DE2
Bottom rad hose fits perfect
IMG_5991
Top rad hose needs some work
IMG_5992
Made a custom top alloy rad hose and added an outlet to the top of the rad
IMG_6123
As the rad was moved right to the passenger side i needed some very small trimming and wanted to push all the air through the rad
Trimmed up
IMG_5993
TIG welded in place
IMG_5998
ground back
IMG_5997
Primered
IMG_6002
and painted
IMG_6018
Radiator wiring done, all contained so a direct plug in connection
IMG_6116
And all completed!
IMG_6136
IMG_6133
IMG_6132
IMG_6131
Here you can see the area left for the intercooler
IMG_6139
Last mod was a little anti social...
Welded a T into the downpipe
IMG_6049
Welded in
IMG_6058
and fitted
IMG_6061
And done
thumbnail_image2
thumbnail_image1
Hi all!
Update time been rather busy
First up was changing the rear bumper to a nice Mk2 one..
Then i had to take a look at the brakes, they were pulling to one side and really needed a stomp to get them to work...
Soon found out why! Pad's were welded in place with rust!
IMG_6359
IMG_6363
Stripped the brakes off cleaner re-painted and new pads
IMG_6358
Much better
IMG_6403
Then i fabricated a new clutch pot as the old ones look nasty
Old
IMG_6341
New with AN4 Lines
IMG_6353
IMG_6354
Next up i wanted to improve the OE airbox as the pipe sizes are tiny and i will eventually be doubling the power
So fabricated this alloy case and s2000 paper filter with ducted inlet from behind the light. This way i get lots of cool fresh air and it allows the engine to breath
IMG_6453
Here you can see the large 3" inlet pipe to the sealed airbox, little perspex window is to make sure nothing gets trapped in the box, 4 bolts allow quick removal and changing of the filter. This all fits in the stock battery tray so no mods to the shell needed.
IMG_7195
So with the new airbox in place i now had to find somewhere to fit a battrey. Didn't want it miles away in the boot and no way was i mounting it inside the car. A few years ago a cell went down in an old car i had and started pumping acid into the cabin of the car... not a great experience...
So here is where the batt was, where the air filter now lives..
IMG_7078
Then i thought, there is some space below the battery tray!
So...
Here is the replacment
IMG_7073
IMG_7072
New mount i made
IMG_6857
IMG_6859
New location
IMG_6861
IMG_6862
painted and foam to protect the batt
IMG_7070
IMG_7071
In place
IMG_7075
And new leads fitted!
The leads are all stock Jaguar parts for the battery and required no mods, i also get the benifit of a fuse which the Uno never had. The only change was crimping new terminals onto the Uno starter leads
Looks OE too
IMG_7071
IMG_7077
So next up i wanted to make a bonnet lifter rather than using the stay all the time
Simple plate that slides into the reinforced section of bonnet to spread the load
IMG_7008
Then a mount bolts onto that
IMG_7010
Here you can see the parts
IMG_7003
The long part bolts in the original airbox mount holes so no holes need to be drilled
The ram is from a Mk4 Golf Bonnet
IMG_7012
Another small mod was finishing the rad setup, i had made a temp top hose out of alloy
IMG_7080
Howver my new AN20 fittings arrived so i welded threaded bungs onto the rad and thermostat and made the new hose
Big!
IMG_6584
IMG_7125
IMG_7127
With the theme of AN fittings i also wanted to make a catch can
So made this tank, here is the inside showing the deflection plates and twin filters
IMG_6778
Fitting welded to the original breather
IMG_6781
Bolts where to the OE air box went so no holes (theme starting here lol)
You can see the drain at the base
IMG_7011
Made the lines
IMG_7189
IMG_7191
IMG_7190
Next on the list is the header tank, hate the big plastic OE one shown here
IMG_6453
So been trying to learn some CAD, made these 2 files over a few evenings
IMG_6570
IMG_6612
Sent them off to a chap with a 5Axis CNC Machine
And these come back
IMG_6822
Fabricated a tank and welded it all up with AN fittings
IMG_6845
IMG_6846
IMG_7079
Last item which is still a work in process is the inlet manifold
Currently my car has the stock Mk2/PGT type
Here is an old pic:
IMG_6131
So, i wanted the better looking Mk1 Manifold but they have a really old odd fuel injector setup, also no spot for a ICV and just need modernising in gerneral
So a stock old Mk1 Manifold
IMG_6366
Here you can see the old style angled injector mounts
IMG_6367
First job was to smooth them out and remove the old mounts
IMG_6406
Both sides done
IMG_6407
Next i tackled the throttle itself. It has no location for a Punto GT TPS and with my future power goals i decided to go for a 57mm (i think) Coupe 20V Turbo throttle body
So, cut off the original
Here you can see the coupe size vs stock!
IMG_6409
IMG_6466
Needs a bit more taking off the stock manifold
IMG_6467
Machined some more out
IMG_6469
IMG_6471
Then welded the new coupe TB flange and also new injector bungs for modern style injectors
IMG_7103
IMG_7113
Started mocking up the rail also, needed some more work to get it bang level but needed to get the holes in place first
IMG_7128
Next up was the throttle cable, needed a new mount for it and i also wanted to suppot the inlet manifold like stock
Made this mount
IMG_7187
Goes here
IMG_7192
and has a step for supporting the manifold
IMG_7193
Test fit
IMG_7179
Quite a bit still to do on the manifold but nearly there... The reason the TPS is facing up is due to the ICV height. Normally the ICV would be straight up but there is no space under the bonnet hence the TB rotation.
