Old 21-08-2019   #1
Trader Rating: 2
punto-paul has donated!
Fiat Uno mk2, Heater not coming on?
Hi all, I've had this issue for a while on my 1993 mk2 Uno 1.1 I.E.
With the interior heater / fan on my Uno, as it doesn't switch on at all?
Not too much of a problem at the moment, but when winter comes it would be nice to have a working heater!!
It used to work sometimes, if I tapped the center console on the dash a bit with my hand. Or would come on after going over a bump in the road, so I figured it's a dodgy switch etc...
I replaced the switch with a brand new one from Fiat, but no good unfortunately. Is there any relays, relating to the interior heater / fan that I can check? Or a fuse or something, as the only option at the moment is to take the dash out!!
To get to the heater box, as the interior heater fan is encased by the heater box.
As it's the only other part I can think of, that might be faulty. If anyone has any experience of this, I'd appreciate it
the uno is fixed Mot'd and back on the road... only took me 7 months!! Im poor, broke and back on the wagon... only took me 7 months!!
punto-paul is offline Reply With Quote Quote
Old 21-08-2019   #2
Iggy64 has donated!
Re: Fiat Uno mk2, Heater not coming on?
Hi. I assume your problem is related to the heater fan not working rather than a lack of hot water getting from the engine to the heater matrix. The fuse should be easy to check out. I think it is number 11 or 12 from memory counting down from the top left in the fuse box and marked with a fan symbol. If your clock works OK, it is unlikely to be a blown fuse though. My guess would be a bad wiring connection somewhere in the fan circuit. Loose or dirty earth connections are often the cause and not difficult to sort if you can trace them. If you have or can borrow a multimeter this will be a great help in checking whether there is power to and from the switch to the fan motor etc.
Thanks punto-paul thanked for this post
Iggy64 is offline Reply With Quote Quote
Old 22-08-2019   #3
Trader Rating: 2
Quote Originally Posted by Iggy64 View Post
Hi, as far as I can tell it's not an issue related to the water. It's just something electrical, as you move the switch across and nothing happens on any of the 3 speeds.
Thanks for the tip on the fuse locations I'll double check those just in case. But the clock does work, and illuminates which is rarity!!
I did have a look again last night around the fuse box, and the wiring loom from that. And found 4/5 wires, one coming from the back of the center console. All with factory looking plugs, but they don't connect to anything.
And don't connect to each other? which is very odd!! So no idea what they are for, they could be spare maybe.
But also I did notice some non factory wiring connectors etc.. on some bits of wiring. But they might be for the radio, or the old alarm. That the previous owner had, which had been disconnected before I bought the car. So I'll get the radio and lower console out, to give better access to that.
Get hold of a multi meter, and see what's going on. Never used one, but about time I started learning
Appreciate the help, and I'll hopefully reply back with an update.
Old 07-03-2021   #4
Trader Rating: 2
An update on this as I took the car off the road, so now it's back up and Mot'd I want to sort this heater. I checked the basics an can find no trouble with the fuse box, but for the life of me I can't find the wiring from the heater fan motor? Searched under the dashboard for a good hour, but can't see where it comes out. As I think it maybe a dodgy connection, on the connector plug from the heater fan to the plug on the wirring of the car.
Is it under the windscreen trim, on the outside of the car? If anyone knows or can help, I'd be really greatful as desperate to get to the bottom of this fault��
Old 07-03-2021   #5
varesecrazy has donated!
Hi again
Did you put a meter( or bulb) on the cables that fit onto the motor?
Did you put 12 volts directly onto the motor.. to check its not seized: dead?
Likes Mike1alike liked this post
Old 07-03-2021   #6
Romania
Quote Originally Posted by varesecrazy View Post
Hi again
Do what Charlie asked here. And mind that the acces to wires on the motor is easy. There could be the problem, they are fit onto the motor by connectors wich could be dodgy. And by testing them (the best way is using a multimetre) you will know if you need to look under the dash for wiring. My bet is you don't need to.
Mike1alike is offline Reply With Quote Quote
Old 08-03-2021   #7
Trader Rating: 2
The problem is I can't find the wirring from the heater motor to check, I've looked under the dashboard but can only find the wirring for the radio an old car alarm. So could someone please tell me, where abouts the wirring from the motor is located? Thanks
Old 08-03-2021   #8
Romania
Usualy you can find them on the heater motor, take that down and you will see them. And tos as Charlie advised you: test the DC on the wires (there, at the end, where they hook to the motor) and test the motor as well, aply 12 V directly to it.
Old 08-03-2021   #9
Romania
*And do as...
apply
(T) Uno MK2 heater fan & clutch fault, any ideas? punto-paul Uno 0 18-05-2016 23:51
