Thread Tools
Old 14-03-2019   #1
South Africa
engine dies when applying brakes
when I apply brakes, the engine dies and the brakes goes hard. is the problem the brake booster or the master cylinder? anybody experience a similar problem
nernstzen is offline Reply With Quote Quote
Old 16-03-2019   #2
Bhutan
Post Re: engine dies when applying brakes
Yes, that's one of the typical symptoms of brakes failure (servo and/or pump).
Plus, I've had the same behavior when my brake fluid leaked out completely one time.
GrandePunto PL is offline Reply With Quote Quote
Old 17-03-2019   #3
Trader Rating: 1
portland_bill has donated!
If the engine will tick over happily when stationary, but then dies if the brakes are pressed, this points at an air leak in the servo. The hose from engine to servo is probably ok as this would cause running problems all the time. Likely the servo diaphragm is split, or might just be the valving. You need a diagram of the inner workings, or a servo rebuild specialist, or a complete rebuild kit if you are competent to rebuild it yourself.
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Thread Tools
(T) Brakes applying themselves?! Alimar Stilo 11 31-10-2013 14:53
(G) Engine dies on me Elxpunto90 Punto (Mk1) 31 10-07-2013 20:13
(G) Spyder dies once it hot and I press the brakes ringovista 124 Spider (Classic) 3 15-09-2009 21:09
(T) Brakes applying themselves mitchell Doblo 4 14-08-2007 09:09
(T) Engine Dies NZUNO Uno 2 19-07-2006 20:29
