My Uno started using a bit of water. The heat gauge shows nothing is wrong but every so now and then do I need to add about 50 to a 100ml of water. This suddenly started.
What should I look for or what should I do?
If a visual check around all hoses, gaskets, core plugs and the radiator don't locate any dampness or staining, suspect the water pump. These usually only leak when rotating, and most of the leakage will evaporate as it is hot.
