Technical Fitting 70SL 1300 radiator on 45 999C engine
chesh
Established member
Hi
I can only get Chinese radiators here and they fail after 1-2 years.
I've seen an aluminium radiator and my friends are using that for couple of years.
https://www.ebay.com/itm/40MM-FOR-F...004925?hash=item520fd60e7d:g:7SYAAOSwImRYM8xB
How can I fit this on the 45 999 engine?
I need a coolant tank + special hose.
I know there are 2 types of coolant tanks, one for the uno turbo version which has 3 outputs, and diesel one which is 2 outputs.
If I get the diesel one, I need to run a hose from the tank to the radiator, but what about the bottom one? where do I connect it to?
