SteveNZ said:
Yes you could actually. They would fit and the engine would run. However the pistons are not suited to turbocharging and the compression ratio would be lower quite a bit lower. The engine would have less power and be less reliable..
Are you sure 1.4 pistons will fit a 1.3 block (without reboring)? Just checked the Haynes manual, and the bore for the 1299/1301cc pistons is 86.4mm. The bore for the 1372 engine is 80.5mm. That's quite a difference!
Plus, don't you mean the compression ratio would be HIGHER when fitting 1.4 non turbo pistons to a turbo block? The turbo pistons give 7.7:1 (1.3), and 9.2:1 on the normally aspirated 1.4.
Higher compression pistons in a turbo engine I would have thought would give more power, but would be more likely to make the engine go 'BANG!' if the power was used! I'd expect blown headgaskets and melted pistons
SteveNZ said:
Best (only?) idea is to use 1400 turbo pistons, Uno or Punto. These fit allong with a 1400 (or 1600) crank. You need to grind a little off inside the crancase to make it fit (easy job). This gives you 1.4L. With a 1.3T head it will have more compression than standard, you could try some tricks to get it down or just use it as is. A 1400 head would give standard compression. At the end of the day its probably easier to get a 1400T longblock and use that.
Hmm, a 1.6 turbo? That sounds fun
Thing is, aren't the crankshafts also different between turbo and non turbo? I'm sure I read somewhere that the 1.3 turbo had a forged crank (very strong), whereas the 1.4 turbo had a fairly standard crank. Not sure if there were many differences between the 1.6 and 1.4 cranks.
I do agree though that the best option is to find a 1.3/ 1.4 turbo long block and use that instead. Or maybe even a Punto GT engine.
But then again, the 1.3 turbo is a super engine and a bit more revvy than the 1.4 as it has a shorter stroke and is more 'oversquare' in its bore/ stroke ratio.
If pistons could be found cheaply then a 1.3 turbo engine could still be rebuilt!
Chas
