General My latest Fiat
Hi, sorry for not getting back to you, I had rear quarter panels but they went to England long time ago, only panel that might of been useful to you is an inner arch panel where shock comes up trough but you have done a grand job yourself.
Managed to get the back door open that was seized closed and found a bit more rust, no surprise there then !
welded a piece in , a quick skim if filler and the repair will be invisible as I a used a joggler to put a lip into the panel and welded it inside slightly lower than the surface to allow for a skim of filler.
Found some more rust near the roof as well.
Still plodding along !
had a look underneath and the drivers side rear jacking point looked a bit worse for wear, lifted up the rear carpet and found a bit more rust, soon had it cut out,ground back to clean metal ready for welding.
