- Sep 2, 2007
- 126
- 112
Hi all,
I'm having trouble locating the starter motor on my 1992 Uno with 1108cc FIRE engine , which is now being dismantled for parts.
If needed, I am planning to transfer the used starter to my other Uno (1993, 1 litre FIRE engine), or keep it as a matching spare. At the moment, I have the classic grating noise after the car fires up but hopefully this is just the engagement lever in need of a clean and grease, assuming the brushes are not too worn.
I found some info from a previous thread when Alex mentioned the motor is held in place by 3 x 13mm bolts (battery disconnected first), and can be accessed from the top rather than jacking up the car.
A couple of photos are attached showing the area where I thought the starter might be (Haynes manual not much help this time).
A nudge in the right direction with the location would be appreciated
Cheers,
Andy
Cheers,
Andy
