When i shift to 1st gear engine gearbox vibrates and no movement of wheels on vigorous vibrations no matter 2nd 3rd 4th 5th or revers is my gearbox broken or what will some one guide me.
thanks:bang:
Hi. Jack one front wheel up,with engine off,put it in fourth gear,and turn the wheel,and listen and describe the noise. Good gear box,and the engine should turn.Bad gear box or clutch,the engine won't turn.
Sound like a problem I had with the driveshaft on the gearbox side sliding out. Apparently the body stretches and causes the shafts to have excess movement
