Thread Tools
Old 09-01-2018   #1
Israel
Electric fuel pump instead of mechanic, and hose diameter
Hi
Are the fuel hoses diameter 8mm or 10mm?
In the pic number 3 is smaller than the others.
I want to change to electric fuel pump but it's only got Inlet and Outlet.
The mechanical pump has 3, one goes to carburator, one from the tank and the smaller (3) goes back to the tank.
Do I need a T piece?
How do I connect it? 1+3 to inlet, 2 to outlet?
chesh is offline Reply With Quote Quote
Old 10-01-2018   #2
South Africa
Re: Electric fuel pump instead of mechanic, and hose diameter
Quote Originally Posted by chesh View Post
Hi
greetings!
you would have to install a T piece, since the regulation of the fuel delivery to the carb is no longer controlled by engine speed, but by the needle valve in the carburettor float chamber.
(remember the mechanical pump delivers fuel based on the rev of the engine)
Once there is sufficient fuel in the carb the return pipe on the T piece will alleviate the pressure and prevent flooding.
Questions;
why are you converting to an electric fuel pump?
what the is pressure value of the electric fuel pump that you intend installing?
--samspeed
SamuelC is offline Reply With Quote Quote
Old 10-01-2018   #3
Israel
Hi, I'm changing the camshaft from the 999 to Punto 866 one.
So it doesn't support the mechanical pump anymore.
It's an "always on" type, 3-5psi it says.
like this:
https://www.ebay.com/itm/12V-Univers...5Yvvbs&vxp=mtr
Old 15-01-2018   #4
Venezuela
Hello there, aftermarket generic electrical pumps are a Headache mate, ratling, noise and overall bad reliability. Wich pump are you fitting?
PNZR is offline Reply With Quote Quote
Thread Tools
(T) Electric Fuel Pump mmarks X1/9 7 03-03-2014 20:53
(T) Fuel Pump/Hose Leak daKlone Punto (Mk1) 1 23-01-2012 11:37
(T) Sisley Fuel Hose Diameter? Palio Panda (Classic) 7 24-10-2011 20:05
(T) Help Finding an Electric Fuel Pump gloverbi 500 (Classic) 1 16-11-2010 11:14
(T) Shimming Fuel Pump or Disable W/ Electric Pump FizzyNose Uno 14 04-01-2009 15:15
