Technical How to remove diesel injector pump from engine
harvestmouse
Hello All
Does anyone here have experience of removing the (Lucas) diesel injector pump from the 1.7L diesel engine in the Uno / Fiorino?
Any advice or links would be appreciated. I can see two nuts holding it on, is there a third one underneath? It's a bit black and oily down there, can't see much.
Also, the cog that is turned by the cambelt would have to come off - is it just the big nut that holds it in place?
Many thanks in advance, as always
It seems that there is something holding the cog onto the shaft, like a circlip.
Hi Peter
Many apologies for the delay in responding. Have had non-Fiat things to do. Will try some WD40. Don't want to break anything, a diesel pump is worth having, even if Lucas made it
You're quite right there. However, I managed to remove the cog. It has a conical joint on the inside. Removal of the cog means that the head of the third Allen bolt to the pump becomes visible. Looks easyish from now on.
