Thread Tools
Old 06-10-2017   #1
Greece
FIAT uno 1,1ies Bosch spi convert to manual choke carburetor.
Can someone inform me how can i make this modification ?
Besides manual carburetor - intake manifold -mechanical fuel pump - manual choke assembly do i need something else?
Is it a straight swap?
stami is offline Reply With Quote Quote
Old 07-10-2017   #2
France
Re: FIAT uno 1,1ies Bosch spi convert to manual choke carburetor.
Your cylinder head might not have all the necessary bits to make a mechanical fuel pump work, in which case you'd have to go with an electric pump.
Steve145 is offline Reply With Quote Quote
Old 07-10-2017   #3
Greece
Steve145 thanks for your reply.
Cylinder head has a metal plate bolted behind cylinder 4.
Remove factory intake-unplug Bosch spi and bold mechanical carburetor and mechanical fuel pump?
Do i keep electric fuel pump(sender) inside fuel tank and connect fuel hoses to mechanical pump?
Do i leave cars Ecu connected to wiring harness?
TPS sensor gives me only problems.
I would like to do it myself for fun and experience of course.
Old 31-10-2017   #4
a73uk has donated!
I`ve not done it, but yes, in theory you can leave the in-tank pump where it is & just connect the pipes (tank to SPI to the inlet of the mechanical pump, pump out directly to the carb, and the return to the old return.
I think the SPi camshaft still had the mechanical pump take off, but check, either by whipping the cam cover off & looking, or, by taking the SPi mechanical pump blanking cover off of the head, placing a pump pushrod through the hole & seeing if it moves when the engines turned.
Currently got.. 1981 Fiat 127 Super, 89 Panda 750L, 89 Uno 70SX (1.5), 90 Uno 60S, 93 Uno 45, 99 Sei Sporting, 2000 Sei Sporting, 96 Jaguar X300 Manual, 99 Jaguar XJR V8, 01 Porsche Boxster, 1989 Escort Mk4 Ghia, 2012 electric motorbike.. The 1990 Uno is the most fun!
a73uk is offline Reply With Quote Quote
Old 09-11-2017   #5
Greece
Thanks a73uk.
Thread Tools
(T) Uno 999 FIRE ie erratic idle on warm up (Bosch SPI) darren_hill Uno 12 07-11-2016 22:45
(T) Fiat factory manual carburetor adjustment jjacob 500 (Classic) 0 24-05-2013 19:01
(T) changing manual choke to automatic choke scottyy Panda (Classic) 3 12-01-2011 23:43
(T) Uno's manual choke chalx Uno 3 26-09-2007 23:27
(G) Fiat Uno 1.1ies Stalling Problems JCV Uno 1 08-11-2004 19:03
