markoibook
- Dec 3, 2004
- 78
- 20
Hi guys,
My little Uno developed a prob this week. The other day as I was driving along, the battery warning light came on - something that I have never seen on before at all!
Anyways, I knew that my battery is a bit duff, so I thought its probably the battery at fault.
Anyways, I wanted to check it was not the alternator, so I did a voltage read across the terminals - about 14V when engine running, and about 13.5 under load.
So with this in mind, I concluded it must be the battery - makes sense I think.
So I went to CAFCO and bought a new battery for £30.
Just fitted it, and the car fires up quite nicely, but the battery warning light is still on.
Whether this is because I've only just fitted the battery, I'm not sure.
The other confusing thing is that the battery light comes on when I engage the ignition - so me thinks that if it was a problem with the alternator then it wouldn't know until the engine is running as obviously the alternator is not working when the engine is not on.
As an aside, the battery light has never illuminated before - the AA man told me that it really ought to come on when you put the key in, but I did just wonder if the Uno did not do that for some reason.
Also, the light does dim when the engine is running, but again I think that is just an Uno "feature".
So any ideas peeps?
I'm looking to change my car anyhow in about 2 months, so do you guys think I should be ok? I'm going to keep the old battery just in case this new one does go flat.
Thanks in advance,
Marko
So any ideas peeps?
Thanks in advance,
Marko
