im Axle Specialists
Old 26-03-2016   #1
Greece
fiat uno 1,1 ies - alternative fuel system
Can i replace the bosch monojetronic system with something else more functional perhaps ?
I have changed complete bosch unit twice(used parts) but i am facing problems like idlig after the idlig stepper motor stops working and for the next 5 minutes and until the engine reaches almost 70 degrees - heavy fuel comsuption when driving in city limits aproximatelly 1/4 for 75kms driving although i have +650kms range in highways cruising with 90km/h - extremely black soot on sparks plugs after 300kms only and excaust tail pipe but no black smoke instead i have white smoke but no loss of coolant or mayo.
I own a fiat uno 1,1 ies (1108 fire engine code 156c046) the past 3 years (2nd owner)
The car is extremly well maintenced before 1000kms
New coil -sparks-timing belt & tensioner-auxiliary belt-coolant-engine oil & filter-fuel filter-gear box oil-disc brakes-pads-brake rubber hoses-ecu-dizzy cap-rotor-impulse generator-vacuum advance unit-idlig stepper motor - clutch- brake fluids-old baterry but fully charged & charnging system is working proper.
My only suspicion is that cold days the car is not reaching operating temperature until i stuck in traffic,the gauge stays below 80 degrees perhaps a faulty stuck open thermostat and that when the mechanic adjust the timing marks using a strobo light he didnt disconnent and plugged the vacuum unit rubber hose according the hayens manual also i notice that i might have bad earth connection since my rear right stop bulb syncronizes slitly with rear right direction bulb
Please enlight me !!!
stami is offline Reply With Quote Quote
Old 13-08-2019   #2
South Africa
Re: fiat uno 1,1 ies - alternative fuel system
Hey am having the same problem with my uno fire 1.1 it was working fine until now bad idling I changed the ECU/Module Swaped the carbs still no change high idling and white smoke coming out of the exhaust, black tail pipe and black spark plugs what was your remedy please help.
tumi1986 is offline Reply With Quote Quote
(T) diagnostic device in 1.4 IES uno Jessica Uno 2 22-03-2009 19:44
(T) Fiat uno 1.1 ies fuel pump ayden Uno 16 31-10-2005 20:11
