darksaint
im building a 3 door uno non turbo ...but i have a fiat TC engine ...looks identical to the 87 mk1 fiat croma turbo ...but mine is non turbo... i need help identifying this engine
does anybody know where i can source a full gasket kit for this engine ...would like to freshen it up b4 i put it in ...would like a broader cam belt also ..& lighter cam pulleys some 1 was telling me that fiat had a twincam engine with composite cam sprockets ...anybody know where i can get a set ??
i need help identifying this engine ...it looks as if its from a fiat croma but its not turboed ....did the croma come with an atmospheric engine ???
I would do some research into this engine. It maybe the GM built ecotech engine that was shared by several other cars.
https://en.wikipedia.org/wiki/Fiat_Croma
This may add some value to the engine or just the cam covers at least. In Fiat car clubs competitive events the engines used usually must be Fiat derived. GM made "Fiat" engines for a while so theoretically you could have any of the ecotech range of engines and gearbox packages from a front wheel driver mid mounted in a small fiat and as long as it had a Fiat cam cover I guess would be legal!
Check this out.
https://www.youtube.com/watch?v=hXXUmUChC-k
whew .... i'm all frustrated .... i'm looking for a gasket kit for this engine... & i cant seem to find any ....does any one know if the gasket kits of the old fiat 2.0 liters engines can fit this engine ....i was told that all the TC engines uses the same gaskets .... what does anybody know of this, because i can get the fiat 135 kits ..... NEED HELP AGAIN :bang:
