well got my instructions for the tacho today, dont understand um to good tho. will quote them and will someone please simplyfy them and explain a little more please!? many thanks you wonderfull people
"1. connect tachometer ground (BLACK) wire negative (-) battery terminal or to a good chasis ground
2. connect tachometer power (RED) wire to a switched + 12V circuit at fuse box, or splice into any vehicle harness wire which is energized ONLY when ignition key is ON (RUN) postition
3. connect tachometer LED memory (ORANGE) wire to battery and (WHITE) wire to night lamp
4. connect tachometer signal (GREEN) wire to appropriate vehicle tachometer signal source
5. secure lead wires along their route to prevent damage from sharp edges,moving parts or hot engine components
6. turn on ignition DO NOT START ENGINE tachometer pointer should rotate to minimum or "0" when ignition is turned on
7. start and run enine rev engine several times and verify tachometer indication changes as rpm increases and decreases make sure tachometer pointer operation is smooth and even"
thanks charlie
thanks charlie
