morphinemitt
- Jul 31, 2005
- 2
- 1
Hi, I'm having some trouble with the brakes on a H reg 1.0 uno, The problem being; sometimes when you brake, the pedal goes straight to the floor and only slows the car marginally if at all. It has had new cylinders on the front and rear, new hoses and pipes all round, has been on a pressure tester overnight, and is not leaking any fluid whatsoever. The problem is sporadic as the car can go for weeks without any failure and when it does play up, pumping the pedal does the trick and the brakes work. Also I think the car has had a new master cylinder, although it may have been second hand.
