Styling Handbrake and Gear Shift
Dima
I got a fiat uno 45S and was wondering if it actually possible to change my gear shift knob and get a sleeve for my handbrake as at the moment the handbrake is just bald... and you can see cogs and etc. not cool!
My gear shift is covered with rubber ... the knob does not unscrew... hmm
Any help would be appreciated.
PS. I can take pictures to help if needed.
And this is my ride:
Been fully resprayed from white :)
Welcome to the forum.
(y) That’s a nice looking Uno you have there!
I’m not sure on the handbrake and gear shifter styling TBH. I think the rubber needs to be cut away, and a new gator fitting. Perhaps some one else will clarify.
Regards,
Louie.
I see thanks!
Does anyone know if the knob will definetly unscrew if i cut the rubber.. or should i ask if the new knob will screw on? :p
Its good when one of your family members owns and works in the body shop.. hehe
Dima said:
I see thanks!
If you need to cut the knob off then it is highly unlikely that there is a screw thread. Aftermarket knobs are usually push on anyway...................
Nice sig & avatar BTW ;)
Right.. I see. Gonna have to go and buy me a new gear shift knob/gaitor then :p
If the knob won't push on then I will have to cut the thread on the stick.. eeeek
cutting the thread of is not a major problem, new gearknobs should have grub screws that will hold it firmly in place, as for the gaiter being a scrounger i picked one of those up cheap with a chrome surround at a car show, have a rummage in the bargain bins
Hi Dima, beautiful paint job there, and such a tastefully dignified colour! :)
The gear lever is moulded around a plastic ball which is, in turn, moulded to the end of the lever. The whole lot is completely un-removable and you will end up cutting it all to bits... also, there are slightly different mouldings for the different trim levels. Yours is a Mk1 45, so the knob is a one-piece affair (the 70 models had a separate disc pressed-in with the shift pattern).
Basically, if you don't like it, just take a hacksaw to it. Make a vertical cut from the top, and when you get to the metal, prise the remains of the knob off with a screwdriver. Bear in mind that someone, some day, may like the original knob back, so you might like to grab a spare from a wreckers and demolish that! Also, fitting the replacement gives you an opportunity to tackle the bush halfway up the lever, which is a common slackness point. Some extra washers and possibly the new bush kit (cheap from your FIAT dealer?) will make a big improvement.
The handbrake should have a plastic grip with ribs on top and finger-indents underneath. If yours has come off, you probably want to replace it with a general do-up part from Halfords. Usually they clamp onto the handle. Be aware that if yours still has the plastic grip, that may also be almost impossible to remove! And so again, you'll end up cutting it off.
It's normal on the Uno for the handbrake lever to be exposed - there is no gaiter as standard, though the carpet has a reinforced rounded hole which might be suitable.
If it's any consolation, the handbrake lever on the Uno has the same grip as fitted to a Ferrari 308GTB/GTS... so I personally wouldn't bother changing it, but in the name of style... it's up to you :) It's the same on my X1/9 as well.
Cheers (and welcome!)
-Alex
Ahh I see thanks for the explanation.
I have now changed my handbreak.. cut that rubber/plastic bit off and put a new handle on with gaiter. Looks much better now. I will leave the gear stick thou as this car not worth spending money on. This is my first car.. saving up for a new and nicer car ;)
Well at least trying to... :p
Have to say that your Uno looks really great in that colour. Looks like a Maroon shade?
By the way, you say it's a 45S. Did it originally have the windscreen surround painted in satin black? Five speed gearbox? Tinted glass?
Either way, it looks really smart, and though I'm not really a fan of colour coding it really works with that colour on a mk1.
Very nice indeed!
Dima said:
....this car not worth spending money on. This is my first car.. saving up for a new and nicer car ;)
:nono: :nono: :nono:
