I have Fiat Uno (diesel 1.7) which has an overheating problem. When the temperature reaches near 100 degrees centigrade, water in the coolant reservoir starts boiling and overflowing from the cap, and very soon the temperature needle is above hundred. My mechanic says there is nothing wrong with the cooling system: he says thermostat is fine and was replaced a few months ago, radiator was just serviced, we also replaced the fan which looked faulty, replaced a bad gasket a month ago too. The cooling is better but the car still overheats after driving around 10-15 kilometers. I have to stop for at least half an hour and fill reservoir again before starting again.
The only funny thing I can notice is water overflowing from the coolant reservoir cap as soon as the temperature nears hundred. I've sometimes even stopped it at 95 and seen water overflowing from the reservoir. I think this may be the problem - the water starts leaking out when the car is near 100 and once enough has leaked out, it heats up even further.
My questions:
- Is it normal for water/coolant to leak out of the coolant reservoir cap when the temperature nears 100 degrees? Could it be something wrong with the cap? I read that it's supposed to maintain pressure in the system, whatever that means.
- No coolant, only water for now since all the coolant leaked out due to earlier overheating. I've since had the radiator serviced and fan replaced. Could adding coolant solve the issue?
- Could this mean my engine is damaged or something? That's what my mechanic seems to think.
My questions:
