Hi All,
OK its good practice to remove the battery’s negative lead first, but all that happens if you short the power is the fuse pops. On the IE version you’d be resetting the ECU too, which may not be a bad thing
Also, the best option would be a direct feed from the battery if you have loud music on when lighting cigs and charging the phone. I’d guess the phone charger is plugged into the cig lighter, so won’t draw any where near as much current as the cig lighter, so you should be OK.
In short I’d say wire in a direct feed for the head unit if you find the fuse blowing too often, but don’t use a bigger fuse as the wire may burn through and set your car alight.
Regards,
Regards,
