Evening all Noob here! Noob to Uno's and the Forum.
LHD 1.ie 1993. Portuguese tax man tried stealing my Landy so that's gone into hiding and I am the proud owner of the above.
Starts fine, once up to temperature it becomes intermittently juddery in all gears under load and just coasting along.
The spring-switch on the throttle assy sits in the depressed position when idling. The throttle assy can be seen moving by itself when idling (have had the car blessed so it's not a poltergeist), raising and lowering the revs between idle-speed and about 1600rpm, guestimate.
Sometimes it cuts out when stationery and a few times whilst driving along under load/coasting.
New HT leads, dizzy cap, plugs & rotor arm. No change
Fuel additive for injectors, no change.
Feels like fuel starvation but it's not because it revs itself up all by itself when idling.
Any help very appreciated,
Regards,
Sef
Regards,
Sef
