I have replaced the gearbox in my 84 Uno with one from an Uno from 87 on. The bottom linkage type.
I have a noise on acceleration in 1-4 but not in 5th. The noise goes away when I decelerate, I am assuming a noisy/failing input shaft bearing.
Am I right?
I assume the gearbox had 200,000km on it, that was what was on the speedo when the car went on fire in the engine bay!!
The gearbox did not have much oil in it when I took it out, I found splits in both gearbox boots later when I went to put the Driveshafts in!
I am not so keen to take the gearbox out again to replace the bearings, but maybe I will have to!
Am I right?
