Technical how to do hood like this?
The bonnet hinges bolt on with 10mm bolts. Just get some longer bolts and some spacers (nuts and washers will do) and then place the spacers/nuts under the hinge.
I have uploaded your picture to the gallery - please note that linking to external host sites is not allowed. The reason: links often break or bandwidth (of the hosting service) is exceeded, so the picture stops working for everyone else.
-Alex
thanx alex
if u have an pic for it that will be better
but as i undrsstand that spas will be fixed mean icant close it agin?
and i try to upload that pic here but i dont how if u have link for it give it to me
thanx alex:worship:
ye dave
but if i cut an seal ,when i run the air Pressure will let the air go inside not the hot air go out.
here in egypt weather is too hot and with air condition my car start to be overheat and i need to let the fans working all the time, and my car have Lower protection made ​​of iron it close the air too can come from down
i dont know what i need to do and i dont want to remove that Lower protection
Thanx Dave
I did that on my turbo.
I loosened the screw in the front and removed the screw in the back.
Then I lifted the hood at the window and placed the screw in the
back under the hinge. Bigger washers will help the screws in the back
hold the hinge. But you can´t close the hood in the back, it will stay like this.
I will be in Egypt some time again for business , maybe I can help you personally ;)
dave
what u think if i done that seals in under engine protection???
johorridoh
u r welcome in Egypt
but till me before u come coz i travel mush time out Egypt
and i cant leave my hood opened like that or thief will steal it :bang:
